Jet extensions, do I need notched floats?
6K views 10 replies 8 participants last post by  TC
I have a Holly doubble pumper I want to put jet extensions in the rear.
Do I need the notched floats ?
It has brass floats in it now.
Thanks T.C.
#5 ·
i cant say a resounding YES!!!!!
cleared my issue right up.
Save
#6 ·
BG makes some jet extentions that are flattened oval tubes that will work with the stock float. We use them on the boats alot because often you get a really steep angle (nose up) while a boat planes out and all the fuel ends up in the back of the bowl.
I also have them in my 950 on the 505
#7 ·
Thanks for the replies:
Not 100% sure the carb needs them but I figure it cant hurt?
It's actually for a friends carb., he has a problem with the motor wanting to shut off if he get into it hard then lets off quickly.
Any better ideas would be appreciated?
Thanks T.C.
#9 ·
If it dies after letting off floats could be to high or fuel pressure just a bit high.
Extensions wouldnt hurt anything
Save
#11 ·
Thanks again for the replies, although one I don't understand?
The weird thing is my friend said he lowered the floats and the problem went away?
But now the floats are to low and that cant be good?
T.C.
