1 - 17 of 17 Posts
fast71ss
Discussion starter · #1 ·
September 2001: My chevelle was wrecked.
November 2001: One last burnout before we took it apart piece by piece to replace the frame.
November 2006: IT'S ALIVE!!!!!
After 5 years of working on it, I spent the entire weekend behind the wheel. I am limited to daylight driving due to a lack of lights, but I still had a hell of a time. The frame sits below the center of the 17" cragars. The manual 12" disks stop it well. The 245/45/ZR17 turn lock to lock with the quick ratio box without hitting fenders or frame. The front and rear sway bars are 15/16" with Speedway 1000lb springs and screwjacks (the shorter ones only opened up 1/2") in the front and MOOG wagon springs in the rear. The bushings are all polygraphite but I dont know if they squeak or not because I cant hear anything over the noisy gear drive and open headers. I can tell its going to handle really well, it seems to hug corners like a slot car. I need an alignment though and I dont have any shocks. Which brings me to my question:
What shocks do y'all recomend? When I got this frame it had an old set of KYB Gas-A-Just on it. I might get another set of those or maybe Edelbrock or Koni. Anyone got something to say about this? I think I want something really stiff. I remember a magazine article that did a shock comparison on a Monte Carlo and they said that the IAS Edelbrock shock was better than the KYB b/c the KYB was too stiff, but I got 1000lb springs so I dont think too stiff will be a problem for me.
Discussion starter · #4 ·
Now that u mention it, I do have a set of sensa-trac monroe shocks that I had installed but had to take off for the new springs. Ill buy a matching pair for the rear and call it a day, now I just gotta find em.
I was just looking at shocks earlier. If you want good and cheap go with Afco 1020 front / 1031 rear.
I had a similar post.
Good shocks in the $70 a pop range:
Hotchkis/Bilsteins
Afco "street stock" shocks: 1020 front and 1031 rear (specifically recommended by Stock Car Products for 900/175 springs, they will also work just fine with 750's up front)
If you wan to spend more there are many options.
These look sweet.
Discussion starter · #13 ·
Those M2 shocks look like they would be more suited for use on my Xterra than on my 'velle. Off-roaders use the shocks with the remote reservoir b/c they supply the extra fluid needed for extreme suspension travel. Those aren't for a car are they?
Why would you want Monroe's if you like the Bilstein??
I spent $150 eaach on the bilstien a few years ago and they aare starting to get soft and they don't have a warranty covering them. For a daily driver, i'd rather go with something with similar performance and ten times better dependability.
Discussion starter · #17 ·
Monroe shocks come with a lifetime warranty, but I believe they consider the "lifetime" of a shock to be 2 years or 20K.
1 - 17 of 17 Posts
