Is there such thing as a window regulator bushing?
2.2K views 4 replies 3 participants last post by  Moloko
Hey guys, i get a rattle from my windows on my 70 velle 2 door. The windows mounts on a piece that runs up and down the main shaft in the window. The hole where the window mount goes on the shaft is pretty large and i think that is where it is rattling. Is there suppose to be some type of bushing or insulation in there? Thanks guys.
Daniel
Save
#2 ·
Beuler, Beuler, Beuler
Save
#3 ·
Your discription is lacking.
The window has a pice of metal bolted on to it at the bottom. This piece of metal has a circular center with a plstic (white) bushings inside of it. There is a metal shaft (taht is part of the door frame) that the afformentioned bushings slides on.
these do wear out, and the shaft does require greasing every few years.
There is a also a metal "tab" with a felt covering that guides the window as is comes down into the door. This too should prevent ratteling when the window it down.
hope that helps. sorry no pictures.
71' 3880# with me. Big Block 402, Merlin oval heads, 10.2:1CR, TH400, 3.73 posi,
1/8th: 8.0 @ 88mph
1/4: 12.5 @109mph w/ 1.89 sixty foot (street tires)
Picture of me roasting the tires and other guy stuff
My other site, picture oriented
-Heart of Dixie Chevelle Club www.chevelle-ss.com
Save
#4 ·
Mike, sorry about the description, but you got it. The first part you mentioned a white bushing. That is the part that i need. Does OPG or Year One make these, or is it junk yard time? Thanks
Daniel
Save
#5 ·
I had an issue with these. My window track broke, the entire bolt/bushing piece shattered and my window came crashing down. simple fix? go to a hardware store and get some hard nylon tubing just big enough to go over the bolt. It works fine, just cut it to the proper length.
Justin Kramer
kman1@ptd.net
1968 Chevelle 300 Deluxe Sport Coupe 350ci
Had a 1978 Malibu Classic 305ci
1987 Shelby-Z Daytona TurboII 5-spd
1967 C/10 Stepside
My Homepage
Mustang Performance; an oxymoron?
