me say to let it skim over, but that makes zero sense to me.
Decades ago we used red and let it skim over and leak city.
I have used Ultra black and Ultra grey and the right stuff and none of those leak.
Black is more pliable and grey is stiffer and Right stuff is like concrete.
Hard to remove an intake with the right stuff on the ends ..you must cut through it then remove intake.
Now the way I do the end seals.
Everything clean and dry and oil free.
Intake gaskets in place.
I tamp sealant into the very sides/corners where the head meets the block on the china wall.
Tamp it in that crevice with your finger and I run a tad bit up to the point on the intake gasket.
I then lay a bead of sealant along the wall tall enough to fill the gap and a tick more.
Immediately stick the intake manifold on.
DO NOT let it tack up or skim over.
If it does then it will not adhere well to the intake manifold. This will cause the top of the sealant to allow oil to pass between it and the intake.
Yea does not make any sense to let it skim over.
Ultra grey is my choice and I have used it instead of the front timing cover bottom rubber seal.
Yes you read that right.
It was my own vehicle and I wanted to experiment as that area has a small gap and I thought it would work and it did.
10's of thousands of miles and still not leaking.
Many newer vehicles use only Ultra grey or something close to it as a pan gasket.
