Hello guys,
Well got the big cam but now have only 8 inches of vacuum left to run my brake booster. So the brake barely work. I bought a electric vacuum pump from MP Brakes but that sucker is heavy. I planned to mount it on the drivers side inner fender where the window wash fluid container was mounted but I'm not sure the metal is thick enough to handle the 6.5 pounds that pump weighs. When this on runs there's no vibration to speak of but I'm concearned that driving the car will shack the pump around and crack the fender metal. Measured the thickness of the metal where the window washer fluid container was bolted on and it measured 0.05 inches thick. Does that sound right? Is this thick enough to handle a 6.5 pound pump without cracking the metal? Any thoughts or advice regarding the placement of this pump would be apprecaited.
Thanks,
Paul
Thanks,
Paul
