Here's what the issue is: "Last time I was able to start it with the key was right after I installed an in dash tachometer. I started the car prior to reassembling the dashboard after that I have been unable to start the car." "I have a 71 Chevelle that won’t fire with the ignition key."
This has everything to do with re-installing the dash after installing the dash tach. You need to go back under the dash and look to see if you knock any connectors off or forgot to plug in connectors, or pinched any wires. Look at all the places where's there's an attaching dash bolt and look for a pinched wire. Then look at your wire harness plugs. Did you re-connect the ignition switch on the steering column? Let us know what you find. Good luck.
