Idle solenoid for speed demon
1K views 5 replies 4 participants last post by  survey_mike
I need to find an idle solenoid bracket for my Speed Demon 850 vac sec. carb. on my '70 Chevelle 502/502 BB. I ran a TH-400 for many
years and didn't need a solenoid but recently installed a 5 speed Tremec TKX. When the A/C comes on the engine dies unless I have
the idle set very high. Neither Holley bracket, 20-9 or 20-47 will work with their #46-74 solenoid. Those brackets are for the 4150 & 4160.
Both brackets interfere with the throttle linkage and don't place the solenoid correctly. I have the solenoid, I need the right bracket to fit
it to the Demon.
Thanks, Mike
#5 ·
Thank you Peewee0413, but I don't think Summit's bracket will work. The Speed Demon is an older carb which was discontinued years ago. The newer
Demons are completely different. I need a bracket where the mounting bolt holes are parallel to the solenoid. The Summit ones are perpendicular.
#6 ·
Thanks Bob, you're probably right.
Thank you for the suggestion Levon. I looked through the ebay listings and didn't see anything that looked close.
The Holley website still has a few Barry Grant things leftover but also nothing close to what I need.
I'll have to use the two I have to make one that'll work.
