I need more wasted motion!
4.6K views 41 replies 16 participants last post by  540ss69
As Pat mentioned, need to check how much front end travel you have. I would start with at least 5".
Slowing the video down, it looks like it is spinning after the front tires come back down and the front end is compressing. Not spinning and then the front coming down. I would stiffen the front shock compression to keep the front up. Start with compression full stiff. Once you get things working you can start backing off to let the front settle quicker and not catch so much air going down the track. Got to hook first though.
Or.....throw some more power at it sooner off the line to keep the front up longer.
Where are front and rear shocks currently set?
