1 - 8 of 8 Posts
shadowgray396
Discussion starter · #1 ·
I just purchased a 70 M20 transmission for my chevelle. I purchased a Hurst shifter setup (used) that came with a lot of parts. I found a set of instructions that a friend had, but believe it is for a different year car. Instruction number 373 3163 391 7308. I think the instructions I need are 373 7834. What I'm looking for is the part numbers of the arms that connect to the transmision that hook to the linkage rods, because the arms I have don't seem to work. If I could get a copy of the instructions that would help alot.
Thanks Ray
What is that "backdrive" linkage rod for? It goes into that #13 bracket, and then faces the front of the car?
Thanks for posting the diagram Dave. I see I have my #10 linkage rod on backwards
that link goes to 1969 Camaro Hurst Shifter instructions
"backdrive" linkage rod is for the reverse lock out that connects to the steering/key lock
I can post the numbers for the trans arms if you still need them
Discussion starter · #6 · (Edited)
If you have trans arms numbers I could used them. I found them on line today Part No. 105 7060
Ray
1 - 8 of 8 Posts
