just thought i'd share this old magazine article. anyone run the manley solid cams back in the day? mike
l"how to make small rats run" - send a mouse after them![]()
And the answer is wieght, big block is about 100 pounds heavier so if both cars have same displacement ,cam intake runner size,and all other variables are the same,the smallblock has 100 pounds less to move,therefore its faster,but on the other hand the big block has more power potential as a 600hp small block is maybe borderline streetable, a 600 hp big block is pretty docile, if built to the level as the 600hp small block thebig block would have 800hp, its what I always say,if you start with more, you end with moreThat's a cool article. I've always wondered why smaller big blocks do not preform in comparison to SBC of equal or smaller CI. Anyone have a idea? All I can think of is the lack of development into heads for those engines in the aftermarket.
I like it, alot.:thumbsup::thumbsup:I've been involved with quite a few 325-350HP 396's and they run pretty well. We had a '68 SS Camaro with 4.88's/Muncie and a 396/325 in it on the street. Used an LS-6 cam, various old school intakes, 850 Holley and headers. That thing ran high 11's anywhere and was a 3600lb car with driver. It had cast pistons in it and yes the pistons did occasionally break. Lost a few motors that way...and only one rod exited one time and whacked crossmember pretty hard. But those engines were $50-100$ max in the 70's at the junk yard. No problem for a Saturday afternoon swap!
I did a 396/375 (with 2 sleeves and lots of helicoiled head bolt holes) with an L-88 cam along with a tunnel ram and 660 Holley's. Muncie trans, 5.57's along with 14x32's in a nice little '68 street SS Nova with full interior (3380 lbs). Ran 10.40-10.60's with 7500+ RPM shifts.
JIM
