How much vacuum is needed to run power brakes
48K views 13 replies 10 participants last post by  Stokerboats
I'm running 12'' to 13'' of vacuum at idle with my 408 bb and I was just wondering if thats enough to run power brakes? My pedal feels a little on the hard side but i dont know if its normal. Thanks, Joe
#4 ·
I also have small booster and it does ok. Works great until stop and go traffic then it gets hard like your saying. I think its normal. Some say you can hear it whining if the booster is bad but there's no way I could over the motor.
Does anyone have the dual diaphram booster on a 68 or 69? I am thinking of getting one and wanted to know if it bolts right up.
#11 ·
Hello, my 396/408 BBC Runs the same vacuum and my brakes suck after a few pumps! Do not spend any money on boosters, they will not make a differance been there done that. WE need more vacuum period!
What cam are you running I have the Comp Cam 270H?
Good luck
Gary.
I got the comp XE268, which is pretty mild but sounds pretty good in gear but i thought vacuum wasnt going to be an issue.
#9 ·
I have 9-10" and my factory setup seems to work real good...better than my 01 Tahoe actually. Maybe the manual trans helps generate more vacuum??
#10 ·
12-13, you should be good. If not, consider raising idle to 800 rpm, I bet you'll get a little more out of it.
Or you can bump your initial timing, and reduce the amount of mechanical advance to keep your total the same - you should see a slight increase in vacuum at idle by doing so.
Might want to drive it first before you mess with it.
