I did a search and found that to make my TH400 shift later I need to tighten the flathead screw in the vacuum modulator clockwise. Is this a micro-adustment or does it take full turns to get a significant difference? For example, the secondary valve spring in a Quardajet is a micro-adjustment -- every 1/8th to 1/16th of a turn makes a huge difference. Is the vacuum modulator that sensitive, or does it take 1/4, 1/2, full turns before a change is noticed?
I know trial-and-error would give me the answer, but since I don't have a space to work on it (street parking and scissor jack) I'd like to have a baseline to save time before I jack the car up-and-down a dozen times.
Thanks.
Thanks.
