How much cam can a 9 to 1 BBC take?
My current cam is 256/262 and 213/219.
A 255 int dur@.05 cam in a 454 with only 9:1 comp running low 11's,was there NOS hidden somewhere? Generally that cam would be too big on duration for a 9:0 comp 454 in reality. I am talking about the avg Joe here that would be caming up his 9:0 comp 454 street motor and accidentially overcam'd it with 255 int dur@.05 with only 9:0 comp. But i am sure a savy engine builder (which this guy could be)could have come up with just the right combo to get a big 255 deg dur @.05 cam to work in a 9:0 comp 454 motor like stated. But it's not the norm for sure & i would not rec anything close to that 255 cam for this guy,wrong thing to do in a 9:0 comp 454 street motor/car IMHO.
Does anyone else think in general that 255 deg dur@.05 in a 9:0 comp 454 is too large and not a good choice or am i missing something obvious here? Heck,i think in general a 255deg dur @ .05 cam is stout/big for a street 454with 10:0 comp. It would likely rock/shake the mirrors off the car at idle,thats plenty of cam for a hot 10:0 comp 496-502 motor with approx 50 more cubes to eat up a little more duration..
As already suggested the Voodoo 60203 gets my vote too as the largest i would install in a 9:0 comp 454,why push it. This cam is conderably hotter then what he is currently running so it should give a decent perf inc without possibly over caming the motor and sending some of his somewhat low( but not bad for street/should have no ping issues) 9:0 comp he has out the exhaust with too much cam.
But if he goes larger on cam then the Voodoo 60203 (227/233 deg dur @.05)whats he gong to gain if he truely has only 9:0 comp as he stated? Who knows he may have smidge less compression because as we all know the est of comp in motors if often in error on the high side and is a little lower in reality then expected so his comp could poss be lowere then 9:0,who knows.
Scott
well I can tell if your serious or being a smart ass but I can tell you that many people never believed that it was only 9:1 compression. The pistons came up as 1971 LS6 9:1 pistons in the GM performance book at the time. I don`t know what the flow numbers were to the heads or what valve size they were either but I know they were on his 12.5:1 427 that had a .650 Isky solid roller and ran low 10`s @133mph. He was running 11.50`s with unported 990`s and when he swapped on the ported one`s he did`nt gain anything untill he did the cam swap. I don`t remember it very having starting issues. He was very good at tuneing it as well. It was a great set up and was very streetable but he was greedy for power understandably. We have lost touch over the years but I hear he has a low 8 second camaro now.SSChevellefan,Wow,thats a nice have your cake & eat it too motor setup,i bet that never detonated or had hot start issues with all that cam in only 9:1 comp.
Thats a great motor setup i bet some T/CR's will copy to run on pump gas for sure.
But those heavily ported heads sure helped it dip into the 11's.
Thanks for sharing the complete story with us on that motor setup.
Scott
no problem, net is hard to tell if people are being a smart ass or not. I know I really liked the way the car ran and planned to copy the motor at some point and probably will someday but i think harlds 288/296 would be a better cam. i think the Chet Herbert was in the low 300`s advertized.SSchevellefan,not trying to be a smart ass at all.
Its a great perf motor combo you told us about and i just wanted to get a little more info on it.
Scott
