reading different posts you see engines with factory 10.25 to 1 compression with iron heads, others build 9 to 1 etc. for a driver type car how do you figure the best all around compression?
I'm still wanting to build a 454 for my chevelle and get the opinions of running .210 dome pistons for 10.22 to 1 a machine shop says stick with a flat top to keep the compression down. a buddy went over the top and but a 12 to 1 motor then found a car to put it in, that car runs best on 110 octane race gas$$$.
I was always taught to go conservative on cams, compression,carb.
Would it be a waste to run higher compression and have to turn back the timing to keep it from pinging or go lower compression and turn the timing up for the gas?
If I do this (eventually) I only want to do it once and be happy with it.
Another idea thrown at me was to just take the block in, have it cleaned, bored and cam bearings installed and order a balanced flat top 496 rotating assembly and drop that in and go. Is it really that simple? jim
