Just did this on my '68 Caprice, my local Autozone did not have any of the tools. I bought a clutch holding wrench, has 3 adjustable studs to fit in the holes in the clutch plate face to hold it still while you use the puller, and bought the puller and installer from O'Reilly, they were Murray parts. The puller is Murray part #59509, and the installer is Murray #59502. You also need a 2 or 3 jaw gear/pulley puller. It was pretty easy once i had everything in hand, the only complication was the gear puller, I had to use a screw from a pitman arm puller that I had, as I did this with the compressor in the car and had a clearance issue with the long bolt that came with the puller. I had about $125 in tools, plus the clutch , but it works well and allowed me to save my original compressor. Do not even think of trying to do it without ALL the tools...
