I had to share the the insanity of the electrical work done by the PO... I'd call it amateur but that would be an insult to amateurs. Chasing wires is fun because he changes colors multiple times in individual lines, white wire, to pink wire, to blue wire, record is 4 colors from fuse box to unit ... he uses repurposed extension cords and outlet cords, he even has speaker wire that he's using for electrical wire for a light in his trunk (which was melted). Primary connection method is twisting wires, wrapping with electric tape, and calling it done.
First two pictures are trunk before and after. What is all that junk? Who even knows. After ripping out all his work I left the fuel pump line, with SEVEN SPLICES in the trunk alone. Seems safe.
3rd picture is a rat king insulated with, you guessed it, electric tape.
4th picture might be my favorite, under the hood, used alligator clips to connect lines for aftermarket lights, and rotting wire totally exposed.
last is the wiring graveyard I've accumulated so far.
Yikes.
Yikes.
