But most people don't initially choose a wheel for the sizes available... Most people choose a wheel for the style, and then check for available sizes...
Why do you need a 10-inch rim? Isn't 8" (15" diameter) sufficient for most tires that will fit in a Chevelle wheel well?
I know I run 295/50s and can't go much larger without body mods (who offers 15" tires in a larger 305 or 315 size anyway?). I think someone offers 325 drag radials, but not sure if those would fit without alot of trimming (they are more than an inch wider than the 295s)... The tread width is the same (on an 8" or 10" rim), and even though the sidewall is shorter, they still fit on an 8" rim (and the 8" is still within the Manufacturers recommended range), without affecting the tread width/contact patch... And the 8" rim doesn't have the clearance problems with the shock mount when centering in the A-body wheelwell...
Since the sidewalls on most tires tend to have a slight bulge that can rub/cut on the fender lip, the narrower rim actually pulls in the sidewall a little more, creating a little more clearance, without changing the overall tread width...
