What is the best/prefered method for hooking a BBC to a hoist to install the motor. I have a leveler for it as well for tilting. I've dropped/pulled a few small blocks but never a heavy BB. It is also going into a '67 which is a tight fit with the oil pan and the trans will NOT be attached.
Any words of wisdom would be appreciated.
thanks
jim
- Is it safe to use a lift plate on top of the intake?
- Lift it from the heads?
- Is there a way to do it without heads on the block?
thanks
jim
