as i remember i used a Moroso 20411 pan, the book said the 13 would fit for stroker, but the 11 clears and avoids the steering problem-Moroso swapped the pan, they know its a problem
(going from memory on the #'s)
if the steering hits, you can adjust at the firewall a little where on the inside plate bolts to the firewall-or you can put a small shim on the steering box where it bolts to the frame, very minor and it move the shaft away from the header
