I will put on a paper suit and paper type hood and crawl right inside the trunk and sandblast over my head or grind over head.
I guess I worked about 25 years with respirators, so I have had my share of time working with them.
This inclued scba, half face, fullface, positive and negative pressure. I also was qualified and trained a lot of others on the different respirators and supplied air systems.
Trust me on this one, if you can get a hood, go with that, I wouldn't consider any type of respirator over a hood.
When you wear a respirator you will have a fatigue factor, a leakage factor, and they are a lot more restrictive. If you have been trained by a professional on how to wear and work with a respirator on, you will be taught on what you can and can't do wearing one.
Theres a lot more to knowing how to use them then what the guy buying one over the counter understands.
Heres what will break the seal around your face and allow airborne particles and fumes to get to you.
Turning your head to far to side, bobbing your head up and down to much, squinting or some facial expressions, talking, bumping the respirator on anything much. Then you take the air supply connected to your respirator, this can be bumped on something.
I don't want to keep harping like a whining old dog, but don't get the respirator, use the hood.
Get a good supplied air unit and learn how to use it, once you practice dragging the hose around you will teach yourself how to work with it.
This is the best tool you will ever buy for doing a full restoration.:thumbsup:
