Thanks Adam!
Those plugs were pretty bad. They always ended up that way ever since I got the 600 holley and put it on my 350 a couple years ago. I'm pretty sure the secondary spring is one lighter than stock. If I remember right I got the carb from Bills Camino off the forum. I traded my Edelbrock 1407 750 for it.
So you recommend I:
1)Stick with this carb.
2)Retune this carb.
3)Check timing and possibly re-adjust it.
4)Get lower gears in rearend.
This brings up a lot of priorities and things that I might want to fix and plan for the future like the rear end and the octane of gas that I will end up running.
Let's start with the first one. This carb will provide enough airflow right? Next one. What should I do to the carb, in order, as far as tuning is concerned. Next one, is their any happy medium on the timing so I can run so I can run pump gas with my 10.6:1 Compression and 8:1 DCR? Last one, maybe I should get a different rear end first and then mod that one and put lower gears in it. I really don't think the 8.2 10 bolt will hold up to this engines profile and possible performance. I've been told to go with a 8.5 rear, and 8.875 12 bolt rear, or a Ford 9". Should I plan for the future while doing these mods or should I just go along one step at a time?
I need to start doing some of this stuff instead of asking questions and bothering all of you like i've done for the past couple months.
I feel sorry for you guys.
You don't know how I appreciate all of the encouragement and advice.
