I have been trying to keep everything original or find a numbers correct engine parts, if a PO has replaced something. But I’am getting a little fed-up with some engine leaks. Has anyone got an old VC to seal and not leak? The main leaks are at the corners. You never know when you have to pull a cover, so I don’t want to seal everything up that it’s almost impossible to get the cover off.
Do you think a heavy beat of black RTV at the corners and a very light bead along the bottom of the VC with the gasket applied to get everything level might work? And then a very light bead of RTV along the sealing surface of the head. Am I going to be able to get the VC off without bending or damaging the VC?
