Guys, I know this horse has been beat to death, but I am at a point where I could really use some input. I have a 72 Malibu. I have striped it to bare bones, boxed the frame, re-welded the sub-standard factory welds, and powder coated black.
So far I have installed or have sitting in my shop the following:
Stage 5 UMI suspension kit.
Currie 9" with 350 gears.
AFX C-6 spindles
Baer 14" & 13" Pro-plus disc brakes.
ZZ6 crate motor. Planning on ordering EFI in the next few weeks.
March performance front drive assembly.
headers, magnaflow exhaust, etc.
As you can tell, all I need is the transmission and drive shaft to finalize my rolling chassis.
Question is?
A 2004r built will handle to 400+ HP and torque, if you can find a decent core, and someone to build it. TV cables can be a pain (I've heard), but isn't a big deal. Love the first to second gear ratio.
4l80 seems bullet proof, but requires a aftermarket controller and does require additional expense for the speedo.
Any thoughts, recommendations, or sources would be greatly appreciated.
AFX C-6 spindles
Question is?
