I did a leak down test on my engine with it cold at BDC because it is out of the car and not possible to run. I had 5% to 7% leak down which seems to be good correct? The problem is at idle it has a faint oil smoke. I pulled the intake off and I can see where the intake ports seem to have a small amount of oil residue. I looked at the intake ports and I don’t think it was leaking or drawing oil from the valley. It looks like it may be a little wet on the valve stem, could the seals be bad enough to cause this? My other thoughts are the guides?
Thanks in advance for any advice.
This is the mess that I got myself into.
Nelson
Nelson
