Hi guys,i have a #'s matching bone stock 1969 chevelle ss 396 with the original flwheel,trans,etc and now have pretty bad clutch chatter.
Before i rblt the motor in 2001 it had a little to no clutch chatter but iafter the rbld is when the chatter showed its ugly head. Durring the rebuild i installed a new std bronze pilot bushing,had the flywheel resurfaced,and installed a new hays street strip 11" perf clutch that has a little more clamping force along with of course a new throughout bearing too.
If i am at a stop and engauge the clutch just right keeping the rpms real low like 500-550 while engauging the clutch it doesnt chatter but oilpressure drops real low while ding this due to the low rpms and i dont like that at all.
If i run the motor rpm up higher to approx 1600-1800 rpms when engauging the clutch then your slipping the clutch too much while engauging it but there is usually very little no chatter doing it this way either.
But when i engauge the clutch at like approx 900-1200 rpms where you should really be while engauging the clutch so you dont slip it too much and its not too low of an rpms where it's easier to stall and the oil pressure goes lower it shakes the car like heck even shaking the hood all over the palce too.
Could the chatter have possibly gotten worse after rebuild due to the slightly rougher surface post having it resurfaced causing the clutch plate to grab it harder and shake untill i get the clutch is full engauged? I have approx 3k miles on the new motor/clutch and the chatter is still the same,no worse or no better and i would think the flywheel surface would have smoothed out some by now reducung the chatter some after 3k miles if that was the case?
Could it also have gotten worse by the hole being made a little to big from the factory in the new pilot bushing (where the input shaft seats ) allowing it to slop around when the clutch is not fully engauged yet?
I have also read that a special heavier duty perf clutch release fork/arm made by maybe LAKEWOOD or someone can help or eliminate this issue,is this true?
Again,this car has never been played with like having parts from different cars & yrs all put together, its all the original parts with only a mild clutch upgrade to a little stiffer street/strip stock sized 11" hayes clutch pressure plate,thats it.
After the clutch is fully engauged the drivetraine is smooth with no vibes at all.
Whats do you guys think would fix this situation?
Scott
Scott
