I'd like to get some opinions on what carb to buy for my hot rod, there's so many on the market its tough deciding, so I'd like to get your ideas. Its not a Chevelle but it is a Chevy. A 41 Chevy PU, I use it for a few car shows a year and a grocery getter and some Sat. night light to light play. I have a 800 Edelbrock on it now because thats all I had when I put it together. I'm not to concerned about gas mileage but I need it to be drive able. I'd really appreciate some input. Here's the specs, thanks
350 late style roller cam block
GM 350 crank
9:73 hyper pistons
Edelbrock cam P/N 2204
Hydraulic roller tappet
Basic Operating RPM Range 1,500-6,500 {I shift at 6k}
Duration at 050 inch Lift 234 int./238 exh.
Valve Lift with Factory Rocker Arm Ratio 0.539 int./0.548 exh.
Lobe Separation (degrees) 112
Cylinder Head, Performer RPM, Aluminum, 64cc Chamber, 185cc Intake Runner,
Air Gap intake
MSD dizzy, 6a, Blaster coil
350 turbo/shift kit and a 2400 stall {I want to get a larger and better stall in the near future}
3.42 posi 28" tall tires P255/70r/ 15
weight with driver 3330
GM 350 crank
9:73 hyper pistons
Air Gap intake
