i need a new more modern grind. new shortblock will be goin together. heres the cars specs.
355, vortec heads with lt4 hot spring upgrade for up to .525 lift, 10:1 comp, performer rpm intake, 750 holley (currently VS but soon to be DP) full msd ignition, 3500 tight BTE converter, 373 gears, 28x12.50r15 et streets. all in a 3350 lbs '72 chevelle. also will be sprayed with up to 150 hp shot of n20.
i need a new cam to go with this. preferably at or less than .520 lift.
i dont care about idle quality or street drivability. lookin for mid 12s NA.
