Okay i bought a 396 engine i think from what i was told came out of a 66 chevelle.i searched and tried to id the engine so i need some help.the code by distributor is 385592. the engine code by water pump on the block deck is t022IIvr and the heads say 6272292 from what i can tell i may have a 396 block with 402 heads any help is appreciated. i tried to install and crank engine but nothing.i did a compression check and came up with about 90 psi!!any thoughts on this was 800 dollars to much. i got ripped cause it was supposed to be a good motor but i know how these games work so im not too dissapointed.
