header issues wit Dart heads 0.300 raised in 66
901 views 1 reply 1 participant last post by  pdq67
putting a big block with the new dart heads in my 66 Chevelle Car is original 138 so has the big block mounts. These dart heads have the exhaust port raised 0.300" so I'm told there are some header issues. Tried both Hooker and Kooks, but both say they don't build a header for this head in the 66 yet. Talked with with Lemons and they can build me a header but if I go with the 2-1/4" primary they will have two pipes over the frame keeping my front tire width to a max of 5". Motor is a 582 Dart block /Dart Head and power is dynoed with the 2-1/4". Haven't asked the design folks how much I'll lose if I go to the 2-1/8", but will have to if I stay inside the frame.
Anybody build this combo before...got any ideas as to what will work of if any of the off the shelf headers will work.
G
#2 ·
Stupid reply??
Can you use home modified "bolted together" stock GM 6-banger/early 350SS Camaro car rubber mounts to drop her down? Or will your pan hit the cross member?
I used mine on three engines fine back then. I tore mine apart early-on and bolted them back together and never took it in when I got my motor mount recall letter. Suckers are probably a 1/2" to 3/4" shorter than locked together poly, imho w/o measuring them?
pdq67
