1 - 5 of 21 Posts
Not aware of there use on the 307 but guess anythings possible.
Here's what I've got:
462624.....75-86...350/400......76cc chamber, 1.72/1.5, 1.94/1.5 or 2.02/1.6 valves
Where did you see the 307 shown for these heads?
Be careful with the compression ratio.
You haven't posted your current engine combo (piston specs,cam specs,etc) so we don't know where you are regarding c/r.
Go too high and your into higher octane gas.
If this is a stock engine configuration ,post the engine id code and the block casting number and casting date as shown
1 - 5 of 21 Posts
