Was woundering if anyone has used this cam part#11-670-4 CB NOSTALGIA LS-6H+ hydralic ls6 replacement cam. What does it sound like and how does it perform.
Brand: Competition Cams
Product Line: Competition Cams Nostalgia Plus Camshafts
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-6,200 RPM
Intake Duration 050 inch Lift: 229
Exhaust Duration 050 inch Lift: 236
Duration at 050 inch Lift: 229 int./236 exh.
Advertised Intake Duration: 276
Advertised Exhaust Duration: 283
Advertised Duration: 276 int./283 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.530
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.524
Valve Lift with Factory Rocker Arm Ratio: 0.530 int./0.524 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash (in): 0.000
Exhaust Valve Lash (in): 0.000
Computer Controlled: No
Grind Number: CB NOSTALGIA LS-6H+
Quantity:
Kingdaddcreel
Quantity:
Kingdaddcreel
