I just got my CNC super victor and it doesn't fit at all. The intake is machined all crooked. I layed it on the block with the gaskets and the front and rear rails have a difference of about .055" side to side. It's not the block, because I put it on the bench and set the carb pad level, side to side and the level has to be lowered 1/16" to read level across the end rails. At first I thought I could fix this but I'm concerned that if the end rails are crooked, how do I know that the sides where the ports are are machined at the correct angle also. I mean the ports line up fairly well, but I can't see the bottom of the intake to say whether or not this thing will be sucking oil out of the valley. I've been up all night sick thinking I spent $600 on something so bad. I called Summit when I saw the problem and they want me to call Edelbrock. I have this sick feeling that they're going to tell me that they have never had that happen before and that it's my problem. Summit says they only have 1 other intake, and they can't guarantee it would be any different if it came from the same production run.
