327 with t-ram twin 390's, New MSD Streetfire HEI wiring is all redone now from the mess it was.
1. The harmonic on this 327 is from what I can measure the 6" dia one and about 3/4 thick now the damn timeing tab extends over it and you really cant see the line and the tab goes to only 12 degrees, I've had tapes before but they just fly off. Are there other tabs? I've not really looked for one I guess.
2. With this setup how do I get to the 35 degrees I'm gonna need? Tape? Should I change the balancer to the wider one? I'm thinkin not.
3. Before I drop the dist. in where should I set the initial timing at? 12-15? I'll have to guess unless I've got a tape or is there a measurement distance from the line on the balancer I can measure and go back to?
Lots of stupid questions but tryin to get my homework done before I start into it. :yes:
