Har anyone bought a GM Performance 502 long block from GM? If so how has it performed for you?
Doug
Doug
If I am correct the Blue Print 502 has a steel crank not a forged steel crank. that is a deal breaker for meSuch as what, better choices? Take your pick, as long as it's not a GM crate engine. Members here are having great luck with Mark Jones engines for one as well as Blueprint Engines. GM is bottom of the barrel.
If you buy the Low HP 502 it is a truck motor, The 502/ 502 HP is a performance motor.I think they come with a truck oil pan that likely will not fit.
That's a $400 addition or more if you need a different pump.
How many crankshafts have you seen broken?If I am correct the Blue Print 502 has a steel crank not a forged steel crank. that is a deal breaker for me
Doug
I believe the GM crate engines are rebuilt from outside sources, NOT GM, GM just sells ‘emThere are success as well as horror stories about GM crate engines. IF, you got a bad one
They do have upgraded forged steel up graded rotating assembly.Call Blueprint and see if they offer upgrades.
Thanks for the information, I already have QA1 coil overs front and rear with there dual adjustable shocks and stabilizer bars front and rear, also tubular A arms.GM 502 comes in a Gen 6 block. If you want a cruiser there are several oil pans. If you are after performance and windage is a concern, you are very limited because of your crossmember and center steering link. If you chose raised port exhaust, you are definitely in for $$$$.
Personally I would build a 489 - 505 out of a mark 4 block. So many more options for everything and they came in your body. A good 489 will give you more power than you can ever use on the street at a much better price. Save your money on the 502. Build a mark 4 block , even a 468, put the extra money into adjustable suspension, double adjustable shocks and good tires and blow the doors off any stock 502.
Rick
Fair point. In fact, I bought a 454HO new, after a "builder" botched my 396 rebuild. Then, I had to disassemble the new 454HO and plate hone/re-ring it as it was an epic oil burner. Didnt notice until warranty was way expired.I find it difficult to accept claims that GM’s Factory Crate Motor program, which released it’s first 502BBC offering to the public in 1991(!), routinely produces a high percentage of grossly defective products but yet remains a going business concern. Are there occasional exceptions? Sure. And if one happened to be bitten by the defect would it leave a lasting negative impression. Absolutely! But these unfortunate events can and do also occur with the custom builders. I’m no special pleader for GM or its products nor any other builder for that matter. I do however believe such discussions should be measured and rational.
