I'm new at setting up gears but I'll get it. 8.2 Pontiac rear, Richmond 3.55 new gears. Started with a .034 shim. Looks to me like I need to add to the pinion shim, right? but how much. Also, I measured the BL where the black dot is in the first picture, is that correct? BL is from .006 to .010 checked on a few teeth around the gear. Thanks, Todd.
Having trouble with the pictures also.
