Hi to all,
I have a 72 Chevelle and I'm going to run a carbed 383 stroker engine. The body is off the frame for the moment so I'm focussing on finishing up the brake and fuel lines. I'm using a 3/8'' fuel line. I was wondering If I have to use a return line and vapor line? The car that the 383 stroker was in before I bought it didn't run any return and vapor line. There is only 1 inlet and 1 outlet on the engine mechanical fuel pump. I'm also not planning to connect/use the canister located behind the back seat. Only the main fuel line from tank to pump and a vent on the fuel tank.
Will I be okay? The car is not a concourse restoration, only a good weekend driver.
Thank you very much!
