Comp Cams claims new surface treatment will prevent flat tappet cam failures
$119.95
COMP Cams DLC High Energy Hydraulic Lifters
The new COMP Cams DLC High Energy hydraulic lifters perform mechanically just as COMP's well-known High Energy line, but with the added benefit of a DLC surface treatment.
This produces a flat tappet lifters with an extremely hard, tough, and slick face that reduces friction at the cam lobe. The unique coating extends the life of the lifter and camshaft, significantly reducing the likelihood of a flattened cam lobe.
Additionally, COMP Cams DLC High Energy hydraulic lifters virtually eliminate the need for the traditional break-in procedure associated with cast iron camshafts and flat tappet lifters. They maintain the excellent hydraulic performance that the High Energy Hydraulic Lifters have provided for many years.
$119.95
