Hi all,
Finally got some positive results with my cooling system, thought I'd share the results.
1970 Chevelle SS clone
Engine is one of MJ's 467, 600hp/600tq, isky cam 228/238@.050, .553/.578 lift, eddy perf rpm, fitech meanstreet.
Muncie/autogear M22Z by 5speeds.com, moser 12 bolt 3.07 gears, M/T ET street ss radial 295/55-15.
When I first installed the engine, I was using a repop two piece 71-72 fan shroud. repop 772 fan and hayden 2747 clutch. Car would get hot at idle (200+) and on the highway (200+). Didn't run it too much, was still working on other aspects of the car. About a year or so ago I went the route of Windstar fans, controlled by the fitech. Temps then fluctuated from 172-185 at idle, about the same on the highway. Still wasn't real happy with it, but at least it was cooler. Cut holes in the shroud where I could, put flappers in it, didn't really help much. Fans never shut off on the highway. If I manually turned them off, temps would creep up to 200+. Never ran it to see how hot it would eventually get, didn't want to hurt the engine.
Finally got serious last week and started to dig in this forum and came across a thread back in 2012 titled "Another overheating BB Chevelle-This week's trend". The op was having trouble keeping cool with his a/c on. Not exactly my problem, but what the heck....
http://www.chevelles.com/forums/32-...rums/32-heating-cooling/384474-another-overheating-bb-chevelle-weeks-trend.html
Page 7, post #98 opened my eyes.
If the engine has no combustion leaks, this is how its done. 1. Locked out dist. 2. Edelbrock water pump. 3. Factory pulleys. 4. Fan must be a Flexolite 1318, spaced half way in, halfway out of the factory fan shroud. 5. 160 stat two .063 holes drilled. 6. Bypass hose installed. 7. Factory HD radiator. 8. The rad must be sealed to the core support. 9. The fan shroud must be sealed to the rad. 10. 70% distilled water, 30% antifreeze, one bottle of water wetter. 11. Fuel run through a trans cooler after the fuel pump. 12. Never run a polished fuel pump. If you can follow these directions exactly, you will never run hot again.
I didn't follow exactly, but here's what I did:
Put the old repop 2 piece fan shroud back on and.....
1. Didn't lock out the dist, timing is 18* adv, 36*all in @2200. NO vac advance per Mark's instructions when I picked up the engine. Even have that comment on vid.
2. Already had a Stewart high flow pump.
3. Factory diameter billet pulleys. All the factory style had too much wobble/runout. Some were really pitiful.
4. THIS IS THE BIG ONE--Installed a flexalite 1318 fan with 2" spacer, fan is about .600 out of the shroud. Plan on cutting .650 off of the spacer to place the fan half in/out.
5. Already had done this from the start.
6. Bypass hose already there.
7.Had a Dewitt's 2 row alum radiator already installed.
8.THIS IS ALSO A BIG ONE--I had huge gaps between the rad and support. Sealed them up.
9.ANOTHER BIG ONE--sealed it up the best I could.
10. Don't really know what my ratio is, didn't use water wetter.
11. Fuel pump is in the tank for the EFI.
12.N/A, see #11.
From the three things I did above, here are the results:
Outside temp 90, humidity 66%, heat index 100
Took about 5 mins to get up to 168. Ran a combination of back roads and highway, temps were 168-170. Never went over 170 in light stop and go traffic in town.
Drove about 45 miles. Parked it in the driveway and let it idle. Temps crept up to 186, then stabilized at 185 and stayed there until I parked it about 10 mins later.
The 1318 fan moves some serious air. Also quieter than the windstars. That, along with sealing the rad to the support and the shroud to the rad did the trick for me.
Hope this helps...:smile2:
12.N/A, see #11.
