More of a rant, but very very open to suggestions.
I joined a car cruise on tuesday, and while it was hot for local weather, it was only around 24-25C (75-77F) and my car just cannot creep at idle. It got up to 240F (sensor in the manifold) before I had to bail out. The crazy part is I put the car on the highway and at 100 kph (62 mph) I got down to 164F coolant temps. 76F temp climb, I could probably do just as well without a fan.
I have a 6 blade aluminum fan. Oddly it doesn't have any real contour in the fins.
I do NOT have any clutch on the fan, it's bolted to the water pump.
Aluminum radiator, no idea the core count or brand.
Factory GM shroud. - the fan could be brought in closer to the block I suppose, as right now the fan is about flush with rear of the shroud.
Timing is at 18 initial, doesn't make a diff if i change it to 22 or so.
AFR is at 13.75, doesn't matter if I make it richer or leaner.
I have 2 temp sensors, so not a faulty sensor.
Weiand aluminum water pump
When driving and there is airflow, it's clear it will cool sufficiently. It seems there is just no airflow at idle while sitting still.
I think I need to get a different fan arrangement, or could it be possible there is something messed up in the water pump that is preventing it from keeping the coolant flowing at idle RPM?
