National Bearings PB-656-HD is a good non magnetic Oilite bearing. It won't appear to have any oil on it unless you heat it up. Then the oil will come out of the pores. I just purchased some on Amazon.
https://smile.amazon.com/National-P...B0052XNFR0/ref=sr_1_7?ie=UTF8&qid=1550433118&sr=8-7&keywords=national+pb-656-hd
SKF B656 is magnetic junk.
QuarterMaster 110013 is a good extended length pilot bushing. It too is available on Amazon.
Sorry! Something went wrong!
Auto Gear, as stated, has pilot bushings and offers good extended pilot bushings.
You need to take a measurement form the trans face to the start and end of the input shaft pilot extension. Then from the bellhousing face to the flywheel. Determine if there is enough room for the extended bushing to clear the fatter part of the shaft. Leave some room for play forward and back
(maybe 1/8 inch).
It's difficult to say what you will need. It's a YMMV type of thing. Different cases, input shafts, and clearances can all affect the stick out length of your input shaft. So it's best to make the measurement then decide.
You can also "short install" your pilot bushing by 1/8" if this will get you within spec. Just don't hammer it in as far. That's what we did before we found the extended bushings. A back in the day type of fix. I would avoid this now since the extended bushings are available off the shelf.
I like to see full engagement of the shaft...Others may have different thoughts....That's my personal take.
