Edelbrock Performer on 283
1 reading
1.3K views 5 replies 3 participants last post by  pdq67
I have a Performer I'd like to put on my 283. However I notice near the distributor there is no cross over like on an original intake. Is this a problem and should I not install it? Am I in for overheating problems? Thanks for any help.
Phil
Save
#3 ·
The carb I have has a manual, cable choke. The manifold itself has no cross over chamber. It blocks off the port in the head when the intake is bolted on. It's a Performer 2101.
Phil
Save
#5 ·
Did the early small blocks have a coolant passage in the rear of the manifold? I don't think i've ever seen a SB manifold with a rear coolant passage,only in the front where the T-stat is located.
Save
