Can ANYONE best these numbers of,
"the earliest known dates, of "just" documented 1970 "LS-5" Chevelle SS454's built at each factory"
___________________________
1970--------TRIM-----BUILD-----ENGINE------POSTEDBY-----DATEPOSTED--------1970----
CHEVELLE----TAG-----SHEET-----CODE-------USERNAME-------ONTHIS------------VIN-----
FACTORY----DATE-----DATE----------------Team Chevelle-----WEBSITE--------NUMBER---
__________________________________________________ ___________________
Baltimore----[--]----[--/--/-?-]-----LS5--------[----?----]---------/--/----
Leeds/KC----12C----12/15/1969----LS5----------RixLS6 ---------04/13/2006 ....[K141523]
Van Nuys----12B----12/12/1969----LS5---------greg2001 -------09/24/2006 ....[L157687]
Atlanta------01D----01/26/1970----LS5--------Dave Birdell-------01/01/2008 ...[A125322]
Arlington----01A-----01/--/1970----LS5----------LevonH---------02/12/2006
Oshawa-----12C----(12/--/1969)---LS5----------waynew -------10/06/2006
Flint--------[-?-]---[-?-/--/-?-]----LS5---------[___?___]---------/--/----
It is entirely possible, there are several other, earlier built 1970 Chevelle / LS5, at each factory ......
Just have not seen/or/heard of many, documented LS5 cars built in December 1969..........
Just need the "EARLY 1970"/ LS5 buildsheet date, trim tag date and the "optional vin number"... Don.
As of...... Jan. 1, 2008 ...
Speaking of only, the 1970 LS5 Chevelle Super Sport's,
the earliest documented cars, that I have seen/or/heard of;
1.Van Nuys built ..12C.....12/12/1969.... Hardtop
2.Van Nuys built ..12C.....12/17/1969.... Convertible
__________________________________________________________________
..Since the 1st known 1970 LS6 Chevelle SS built at Baltimore.12/9/1969 .... 12B ....
..It is also widely known that the, 1970 LS5 Monte Carlo SS were being built
as early as "October 6, 1969"..... and, possibly mid-September ......
Miscellaneous interesting 1970 Chevelle LS-5 factory build information.
I run across ads, quoting different production numbers for the 1970 LS5 Chevelle convertible.
Is there any actual published production numbers??
Dan Carr's poster (
http://www.designscomputed.com/auto_pub/a_body_68_72.html) is the most unbias I've seen for engine/transmission/series/model combination numbers cruncher.
He puts the probabilities of LS5 convertibles at:
w/o ZL2 hood - 27 w/4-speed and 22 w/TH400
with ZL2 hood - 23 w/4-speed and 19 w/TH400
Remember, these are proportional numbers only. If you look at the 1970 LS-5 coupe numbers ...
w/o ZL2 hood - 1148 w/4-speed -and- 980 w/TH400
with ZL2 hood - 992 w/4-speed -and- 844 w/TH400
...that's 3,964 plus 519 statistically viable El Caminos gives a total of...
3,964 + 519 + 91 = 4,574 (plus another 3823 in the Monte Carlo).
Are the numbers absolutely 'correct'? Chances are, no but they are statistically probable. Given the number of
possible Chevelles that
could have the LS5 (2-dr coupe/ 2-dr convertible/ Custom
El Camino), convertibles are roughly 2.1% (0.021159082760725471197750458530746) of the total.
That's roughly 2.1% of 4574 LS5 gives you 96 LS5 convertibles.
BTW, a plug for the poster -
http://www.designscomputed.com/auto_pub/a_body_68_72.html - it's well worth the price. :thumbsup:
I believe there were actually less LS5/M22 Chevelles in 1970.
I find 2,763 were built with that combination, and have the engine code CRT, but that also includes the service engines.
Those of us who do a lot of research on 1970 cars in particular, have become more forgiving about date lead times. It seems especially 454 cars (LS5 and especially LS6) commonly have more date variations. Parts like your rearend are specific to the 454 car, and since they are made in lots or batches, the lower the useage, the more time between the lots or batches of parts made. Also, certain plants seem to have had a higher percentage of this happen.
I have seen the #1100837 alternator with a date of 9H6 on at least [5] late 1970 cars built in Baltimore including my personal April 1970 built El Camino. A lot of these cars also have a December 1969 built rearend. These date variations can be considered normal, and are not just confined to high horsepower cars. I had a 402 block one time, cast in Jan 70, and not built until Aug 70, and the Stamp said it was for a 1971 402 300HP Camaro. Answer I got from Tonawanda historian was block probably had a flaw, and they would put it aside and fix flaw when they had a shutdown between year changeover (70 to 71). They would then use it up immediately on the first run. Makes sense in this case. Anyway, don't sweat your case, this is somewhat common.
Jeff Dotterer
Dated Components
Former NCOA Senior Judge
Current Diamond Restored Judge
My 512 block is Oct 69, - Rearend is Dec 23 69 and - Trans is April 23 70 in an 05D Arlington car.
I have 2 POP's and the build sheet. All numbers matching.
There was a thread earlier this year and one of the posts was from a guy who worked in Tonowanda. He stated that everyday there were blocks that got pulled off the line for every reason you could think of and got sent to a repair area to be fixed.
Sometimes they sat for weeks or months until they were repaired and shipped.
So who knows what ended up where.
I have a 1970 SS454 black with white stripes, bench seat, M22, matching numbers. Also have build sheet and documents from vintage vehicle in Canada.
Built 3rd week of December 1969, and shipped to Curry Chevrolet in Scarsdale N.Y.
My SS454 was built 3rd week of December in Oshawa Canada .
Great info....I have a Baltimore LS5 built 03A cowl tag - 02/20 Build sheet & (01/27) motor.
I have a 1970 454 with owner history and buildsheet. My car was built in Atlanta on Jan. 28th.
Here are all the numbers on the block.
#3963512
TO1I3CRT
#10A128601
J 24 9
I've had this block for several years. It came from the east coast.
Casting #3963512. It has an assembly date T1208CRQ
The partial VIN# is for a Canadian built 1970 Chevelle LS5. [101529413]
My Baltimore LS-5, 512 block cast [L 18 9],heads A 17 70 and A 21 70, engine assembly Jan.23,1970, 01D body plate. M-22 trans Dec.19,1969. Rear Jan 20,1970. All pretty close.
Dec. 1969/ Z-15 Chevelle build dates .....
B126084 12B L78 build date 12-04-1969
B127012 12B LS6 build date 12-09-1969
..... other early built Z15 cars .....
L157687 12B LS5 build date 12-12-1969
A119029 12C LS6 build date 12-15 "
K141523 12C LS5 build date 12-15 "
L159008 12C LS6 build date 12-16 "
B129B53 12C LS6 build date 12-17 "
K144677 12C LS6 build date 12-19 "
B130498 12D LS6 build date 12-22-1969
