bb489 said:
What kind of dyno?
Engine?
About $450-$500 a day
Some places are pretty laid back, others are very "structured"
I happen to fall into the first category,,
Questions,,,
Your fuel or supplied
Water pump or supplied, some are set up to use an electric one
Is the engine complete, primed, basic timed, valves adjusted,,, ready to run?
The closer it is to running the less it is going to cost you.All this stuff takes time & time costs.
Ignition system?
Dyno headers, your headers engine been broken in yet on a stand or new
Bring jets, fuel if necessary, headers if you intend to use yours, assuming they will fit the dyno in question
Are you allowed to do your own tuning so all the operator has to do is pull the handle & make suggestions?
If you have leaks or other issues will they let you do the repair so you don't have to pay extra?
Are they so busy you have to get in & out or will they work with you if there is any issues?
There is no easy answer to your question, some sessions just go better than others,,
Chassis dyno,,,, don't have a clue,
Someone else will need to answer that.
