1 - 1 of 7 Posts
Do you have a vented yoke? If your yoke is not vented YANK THE O-RING OFF THE OUTPUT SHAFT. You'll starve the splines for ATF which lubricates them. If the yoke is vented, you need the O-ring, in addition, you'll need to assure that the splines are lubed with the special spline grease.
Save
1 - 1 of 7 Posts
