Could use a little math help on determining the drive/driven gears on my 69. Muncie M-20 3:07 gear P245/60/15 TA radials Thanks.
L larietrope · Registered Joined Mar 14, 2007 · 672 Posts Discussion starter · #1 · Aug 19, 2008 Only show this user Could use a little math help on determining the drive/driven gears on my 69. Muncie M-20 3:07 gear P245/60/15 TA radials Thanks.
A animal69 · Premium Member Joined Mar 10, 2006 · 3,509 Posts #2 · Aug 19, 2008 Only show this user 4th gear 3.07 to one. Year 1966-1974 Type: M20 Rings: Two Ratio: 1st 2.52 /2nd 1.88 /3rd 1.46 /4th 1.00 /R 3.11
J JodysTransmissions · Premium Member Joined May 6, 2005 · 1,854 Posts #3 · Aug 19, 2008 Only show this user You'll need a 1.840" diameter 8 tooth drive gear and a 19 tooth driven gear for your speedometer/odometer calibration.
