Seasoned bolts should be good to go if they are properly torqued. New bolts should be torqed, loosened and retorqued at least 3-4 times. Once this is done they should be good to go once the engine is running assuming they are all torqued correctly.
During the rebuild, the bolts should all be torqued at least three times to insure none have loosened while the surrounding bolts have been torqued and that none have been missed. Always follow the appropriate torquing sequence even when simply retorquing already tightened bolts. I usually run through each set of head bolts with 4 tighten-loosen cycles and then run through the torque pattern 5 times. This may be overkill, but it provides a decent upper body workout and leaves less to chance. I find it helpful to count the bolts as I torque them so I know I've hit them all.
