In general, just the gear ratios. M20 had a more aggressive 1st gear ratio, M21 was less. If you plan to use one vs. the other, make sure you take your rear axle gear ratio into consideration.
Here's a good reference site for your education on Muncie's: http://www.5speeds.com/muncie.htm
Save
The only difference between an M20 and an M21 parts wise are the input gear and cluster. Everything else is the same.
Save
The only difference in the two is the input and the cluster, all other gears are the same.
Standard M20 is a 2.52 low gear, M21 is 2.20 low. The super early M20, 63/65 have a 2.54 low gear.
