I am cleaning up the rear window channel and found the leading in the upper corners to be still intact and the track in fair condition with only one pin hole to weld up.
Now, both lower corners have a bit of brazing done for about a 1 1/2 to 2 inch section where the rear filler panel between the window and trunk attaches. Is this "factory" or has there been a repair done?
Another thing that looked a bit weird were two metal screws with bits of the original vinyl roof still under them. These were within about 1/2 inch of the brazed area and the vinyl did not appear charred.
Now, one more question....... is there anything that will take off the last bit of the window ribbon adhesive? Paint thinner, laquer thinner and acetone didn't work!
