Joe, its a 8-32 or 10-32 screw I dont remember, but what I did was went to ace hardware and bought a small nylon bushing, the bushing was still to big for the diameter of the hole( in the pod), so I took the 8-32 or 10-32 screw and ran it to it, then I went to my trusty dremel and mounted the dremel in the vise and put a sanding wheel on it, then twirling the screw and nylon piece against it I made my own bushing, takes a while but works great, make it small enough so it dosent bind, also dont over tighten it that will also make it bind up, I also put a stainless flat washer on the end of bushing where it is going into door, snug it down back off a 1/2 turn and your ready to Rock and Roll, good luck, Mike
