Cost of rebuilding 350
7.5K views 6 replies 6 participants last post by  MarkV2
Ok, I'm wanting to ask you motor heads what you think it would cost to rebuild a stock chevy 350???
I'm talking, cheapest I can get by with.
I just need a running motor int he chevelle for now.
This is going to be a chevy 350 out of a truck that a friend pulled out.
I was told that the motor ran when it came out of the truck, just sold the truck body.
I'm sure the truck had a few miles on it.
I'm hoping to just get a rebuild kit for it, the ones that have rings, gaskets, bearings etc.
My budget would be no more then $500. I don't have any more to spend on the 350 now.
(Later, I have another 350 parted out that will be a 383 for it)
What would be the cheapest I can get away with and have a running 350???
scott
#2 ·
The cheapest and safest route would be to buy one from GM. I believe they are around $1200 but I haven't looked in a while. You could buy a reman through one of the chain parts stores for less, but its a roll of the dice going that route. To properly rebuild it you're looking at spending a lot more. With $500, you're better off buying a whole car with a good running engine if that's all you have to spend.
#3 ·
scott
You will not know what you can get away with using the current motor till you take it apart, look at the cylinders, measure the bore, check the crank.
I did a re ring job on a 305 motor for an 84 Pontiac Grand Prix. Had 185K on the motor. I didnt check anything!!!!!.... just threw in new bearings, oil pump, new timing chain set, cheap cam and lifter set for under $100. I think for the Re ring kit including all gaskets, all bearings, and oil pump I paid under $200. I spent another $20 I think it was for a ridge reamer so I could get the pistons out without any damage, and I spent another $40 or so for a a couple of ball hones..one for the cylinders, and one for the lifter bores. Motor went over another 100K miles...but not checking anything as I did is kind of a crap shot and Id never do it that way again...Good luck
#4 ·
Contact a local engine retailer and get a short block. Most shops will take your block in trade. Get the heads cleaned, guides checked/installed with new seals, Buy a gasket set and put it back together. My Dad just bought a 350 2-bolt short block for around $325 for his Elk.
Another option is to get a long block and trade your short block and heads. You keep the intake, water pump, harmonic balancer, etc. Guessing maybe around $500-$700 for a long block
Here's a couple of shops that local outlets in Houston:
Warren
Northwest
You should be able find one local to you.
E.
#5 ·
Ok, I guess I wasn't clear.
I already have a 350 motor, I'm getting it from a close friend. I was told by my friend that the motor was running fine when it was pulled.
I want to take this motor, and rebuild it. Something like a re-ring kit.
I'm looking for a $$$ amount of how much it might cost to take a running, tired 350, and rebuild it to a point that its ready to run another 100,000 miles.
I guess taking the motor apart and having the block cleaned and checked over will be good. That way I will know what/ if anything needs to be done to it.
What whould the cost of that be? $75?
thats what Im looking for, give me a $ amount of what it would take to rebuild a stock 350, other add-ons can be "Added-On" later.
I guess I wouldn't think it would be more then $500 to rebuild/freshen-up a stock 350.
scott
#6 ·
Several weeks ago I got a 350 short block from a friend for free. I went to a local rebuilder to ask what it would cost. Answer : $800. No thanks. I ordered a long block from a rebuilder in Phoenix that wanted $900 without a core engine. Took that. The local dealer wants $1800 for a Goodwrench motor. Anyway, I would do a compression test on that motor and ask if it burnt oil in any quantity. To do a good job and get 100,000 miles more will cerainly take more than a couple hundred dollars. If the motor is in good shape, then put in a timing chain, crank seals, check core plugs for rust and leakage and maybe add a set of umbrella seals on the valves. That could keep the costs down and give you a reasonably good engine.
#7 ·
Cleaning the block, an over bore, resizing rods, new rod bolts, cam bearings installed, bottom end, and rod bearings, pistons, rings, oil pump, and gaskets... I would say 700 to 900 bucks depending on rod bolts, and pistons.
If the motor ran ok before, and you want to build a 383 for later, I would just put it in, do a good tune up on it, and save the 500 bucks to spend on the new motor.
